Help Install PLX wideband
Re: Help Install PLX wideband
You will need to look at the documentation that came with the wideband and then use the instructions we provided to wire it to the ECU.
Xtremebb20
Post by Xtremebb20 »
not sure where to post this ? so its going here. I just installed the PLX wide band module gen 4 in my crx and removed the R136 and R138 resisters now I'm getting code 43 on smanager and P0169 on the hondata app. code is for Fuel Compensation and was wondering how I can fix this. I seen that my S. Fuel trim dips to -30 and that activates the cell after that is stays around 2 the a/f is at 13.22 any thoughts? Engine is spuddering while under steady throttle. I also looked at the datalog and my Short Fuel trim is all over the place. I attached a datalog to see if this helps.
It probably needs to be properly tuned.
Xtremebb20
yeah I figured that lol. I just got all of it put together and now it don't run right. oh well Humble is 2 hours away.
Xtremebb20
hey spunkster did you get a chance to check out the datalog?
It's really hard to tell anything from just a datalog and no calibration, but it sounds and looks like it is probably just a tuning issue and once properly tuned should run properly.
