Need built D16 Basemap for start up/break in
BPerry99
Post by BPerry99 »
Hey there, i just got my hondata S300 v.3 and was curious if i could have a basemap made up for me to start my car and break the motor in, and so that i eventually can go to a tuner for a proper dyno session.
I am only looking to run about 10PSI or so on this basemap but plan on running 15PSI when i go for an actual tune.
The setup
D16Z6 Head:
- Bisimoto titanium retainers, valves and springs.
- Bisimoto 1.2 camshaft
- Bisimoto adjustable cam gear
- ARP headstuds
- Nology spark plug wires
- 3 Bar Map Sensor
D16Y7 Block:
- FJR Spec connecting rods
- Vitara pistons
- ARP rod bolts
- ACL race bearings
Edelbrock Turbo kit
- PerformerX intake manifold
- Tial blow off
- Edelbrock cast log exhaust manifold
- GT28RS turbo
Fuel:
- AEM fuel rail with AEM regulator
- Injector Dynamics 1000cc injectors
ECU
- Hondata S300 Verison 3
Let me know if there is anything else you may need to know about the build.
Thanks in advance for anyone that is able to help me out!
