Wideband is not reading right in my data logs
Boostedsi
Post by Boostedsi »
So when I start the car and start logging my af matches my wideband on the dash , and I can even start recording my log and it is fine. If you record it through the Ecu the af goes crazy and does not read right ... Anyone have this problem?
AREA876
Re: Wideband is not reading right in my data logs
Post by AREA876 »
Boostedsi wrote: If you record it through the Ecu the af goes crazy and does not read right
What do you mean by that is it freezing or are the values wrong
Boostedsi
Post by Boostedsi »
Like the ar on the Ecu recording way off . 60to 1 28to1 af . But it is right when I am live traceing.
Boostedsi
Post by Boostedsi »
How is the value right in live traceing but wrong when the Ecu recorded is in the Ecu ?
AREA876
Post by AREA876 »
Post your calibration and a datalog showing the problem
