please help with idle problem
Posted: Tue Aug 11, 2015 11:40 am
by creedy
my car has started to not idle on start up, it will start and run at 2000rpm then drop slowly then just stall.
its on itb's and has been sat for 3 months doing nothing
Re: please help with idle problem
Posted: Tue Aug 11, 2015 11:56 am
by AREA876
Which version of S300 do you have (V1, V2, V3)
Posted: Tue Aug 11, 2015 12:08 pm
by creedy
v3
Posted: Tue Aug 11, 2015 6:08 pm
by AREA876
I would start by checking the map sensor because from the datalog I'm not see the map sensor reading change
Posted: Tue Aug 11, 2015 11:18 pm
by creedy
Map sensor not connected it doesn't use it. I'm running itb's without a vacuum chamber
Posted: Wed Aug 12, 2015 9:33 am
You must have the MAP sensor connected.
Posted: Wed Aug 12, 2015 11:42 am
by creedy
It hasn't had one connected for over a year and worked fine
I'm guessing it's how it was mapped (I know nothing about mapping)
Posted: Wed Aug 12, 2015 1:46 pm
You should probably take it back to the tuner to have them take a look.
