Erratic air fuel ratio on b16 84mm turbo
Posted: Sun Aug 02, 2015 4:34 am
by Reezo
Good day
So I just complete my build :
sleeved B16 84mm
Wiseco pistons 8.8 comp
Eagle conrods
Custom log style intake manifold , no iacv (been disabled on s300)
63mm boost pipes
A/r 50 intake and 48 exhaust turbo
Ebay 38mm external wastgate
EBay dumpvalve
Aem wideband gauge unit 30-4110
Ram horn style manifold
Precision 880cc injectors
Stock map sensor (for now )
Hondata s300 with obd2b jumper harness.
So my tuner loaded a base calibration and we got car started . after many attempts we can't get the air fuel ratio to remain constant it jumps around from rich to lean . the distrubutor timing is at 17° which relates to value in s300 , Map reading 0.32mbar , injectors at 1.22ms which is constant . this erratic air fuel ratio continues even if rpm is held at 2000rpm .
I will attach the calibration as well as a datalog .
Kind regards
Reece
Re: Erratic air fuel ratio on b16 84mm turbo
Posted: Sun Aug 02, 2015 7:33 am
by Reezo
This calibration attached is just some changes we done today , air fuel is a lil more stable but they not as consistent as I want them to be .
Posted: Mon Aug 03, 2015 3:15 am
by Reezo
ANY HELP PLEASE ?
I WILL BE CHANGING OUT INJECTORS TO 900CC FUEL INJECTOR CLINIC UN THE HOPE IT HELPS
Posted: Mon Aug 03, 2015 8:47 am
by hpmx18
did u put the dead time what pte say the 880cc are suppose to be when i have issues like that its either dead times or fuel issues could b injectors or fuel pump or fuel regulator sometime even a fuel line
Posted: Mon Aug 03, 2015 9:38 am
Where is the wideband installed?
Posted: Mon Aug 03, 2015 11:42 pm
by Reezo
Good day
I have tabulated injector dead times as per precision specs supplied to me by them .
My fuel pressure is a constant 40psi at idle .
And my wideband sensor is installed as per aem specs .
The injectors are brand new tho ? That's y I'm confused here , I can't seem to pin point the prob .
Spunkster , taking a look at the calibrations and log file can you see nothing odd ?
Kind regards
Posted: Tue Aug 04, 2015 6:34 am
The injector dead times are much too low, but I think there are other issues as well. If you look a the datalog the manifold pressure is fluctuating a lot. I suspect that the base ignition timing is off too.
