Help please, H22A turbo, lean after warm up
haRRibo
Post by haRRibo »
please can you somebody have a look on my tune?
when is engine cold everything is ok, but after warm up is getting lean
Eagle rods
CP pistons (87mm low compression 8.5:1)
BENSON's darton sleeved
Supertech dual valve spring set
Supertech exhaust and intake valves
Supertech titanium retainers
RC 750 injector high impedance
Fuel pressure regulator
Warlbro fuel pump LPH 255
GM 3bar MAP sensor
Hondata intake gasket
ARP head bolts
Tial wastegate F38 set for 1.6 bar with springs
Garett T3/60-1 turbo –
Turbine Housing SPA A/R .63
Fidanza lightened flywheel
Quaife slip ATB differential QDF5U
Innovate Motorsport LC1 programmable wideband
Innovate Motorsport MTX-D – oil temp and pressure gauge
AEM boost controller
Hondata S300
hpmx18
Re: Help please, H22A turbo, lean after warm up
Post by hpmx18 »
post a log of when the car starts till when it starts to lean
LGMotoring
IG:Lgmotoring_official
Lgmotoring.com
haRRibo
Post by haRRibo »
here is it
hpmx18
Post by hpmx18 »
i am unable to open the tune you posted can you try to post it again i see the log but with the file not opening its hard to try to figure out
LGMotoring
Lgmotoring.com
haRRibo
Post by haRRibo »
try now
haRRibo
Post by haRRibo »
any suggestions
hpmx18
Post by hpmx18 »
i cana open the log but not the tune can you reupload the tune so i can see
LGMotoring
Lgmotoring.com
haRRibo
Post by haRRibo »
here you are
H22A turbo.skl
