k24 rsx map ?
tylermep3
k24 rsx map ?
Post by tylermep3 »
can anyone help me out with a k24 map for my rsx specs below much appreciated
k24a2
shorty header
2.5" exhaust
rbb intake manifold
70mm throttle body
short ram
davinadze
Re: k24 rsx map ?
Post by davinadze »
got one tuned for k24/k20 maybe it will help. got one 520cc injectors and 310cc
520cc injectors. k24/k20a2 head, tsx 06+ cams, RRC maniforld/70mm port matched TB, 4'' custom short ram-cold air intake, Tri-Y header to 3" exhoust.
Matt_Shue_Tuned_K24a.. 510cc tuned buy D.P changed cam angles.kal
davinadze
Re: k24 rsx map ?
Post by davinadze »
310cc injectors. k24/k20a2 head, tsx 06+ cams, RRC maniforld/70mm port matched TB, 3.5'' custom short ram-cold air intake, Tri-Y header to 3" exhoust.
olivenoire
Re: k24 rsx map ?
Post by olivenoire »
It is really great for you to share a map.
People must be advice to add a bit fuel or remove timing before upload...
Great anyway!
Ep3 eudm
K20a turbo
Kpro v4
The unwanted AEM 30.4100 WB AFR
5j0k3r
Re: k24 rsx map ?
Post by 5j0k3r »
Is this for a k24a? Or What k24 is it for?
Buffep3
Re: k24 rsx map ?
Post by Buffep3 »
Runs great but my check engine light flashes here and there randomly
Danksanatra
Re: k24 rsx map ?
Post by Danksanatra »
I tried to use this tune, but kept getting knock and I can't wot without hitting lean protection close to 5k rpm
Setup
K24a/k20a2
06 tsx cams
Vtc-50
Ktuned race header to 3” exhaust
Rbc manifold
rufer
Re: k24 rsx map ?
Post by rufer »
I have a 02 RSX Type S I recently swap my K20a2 with a JDM K24A, I have Kpro V4 I tried the MAP for RSX with K24A2 intake and headers I think but it kept bringing up my Speed sensor check engine light, So I Finally use under Others TSX STOCK CAL and it work fine for 2 months, so I recently put my previous Cut RBC manifold with Hondata IMG, I had to get the Ktune coolant adapter and connected my Injen CAI, the car run good for 1 week now is running lean and rich most of the time also stalls at idle and while running, I'd been researching on google and here and cannot seem to find any solution to my problem, is there a better fitted calibration or tune preloaded on KPRO that I can use? again my mods are:
stock RSX type S transmission
JDM K24A Motor with Original Fuel Injectors
CUT RBC manifold with KTUNE coolant adapter (if that makes any difference)
Injen CAI
Kpro V4
Austinmr2
Re: k24 rsx map ?
Post by Austinmr2 »
Lmk also. My tsx map worked for a year then it went lean. Idk why.
Jdm k24a
Rbc Cut
80mm Ktuned TB
4" intake
3" exhaust
MR2 Kswap
Someone provide me a map please
Cold starts at 10-13 then goes to 17s 30second later
Austinmr2
Re: k24 rsx map ?
Post by Austinmr2 »
310cc injector
