s300 in 00 integra
boosted crx-r
s300 in 00 integra
Post by boosted crx-r »
what do i need to do for the s300 to work in my obd2b integra? what has to be done to bypass the immobalizer system so my car will start??
shut up and boost it!
Re: s300 in 00 integra
To use a Hondata system, you will need to use a compatible OBD1 ECU from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
boosted crx-r
i have the s300 and adapter harness. just need to know what to do so my car will start since it is equipped with the immobalizer. ive used and tuned with s300 for years but was always in obdo or obd1 vehicles.
By converting to OBD1 you have already eliminated the immobilizer.
