All motor h22a map
Posted: Sun Jul 19, 2015 2:20 pm
by h22aeghatchback
Hello I'm wondering if any can help me out with a map for my h22a
11.5.1 comp cp piston standard spec
H beam rods arp head bolts and main bolts
Port and polished exhaust ports
Brian crower valve springs and retainers
Brian crower 3 na cams
4-2-1 eBay header 2.5" exhaust
Walbro 255
70mm alpha throttle body port matched stock intake manifold 650cc injectors
This is in a eg hatch m2y4 trans
Thank you
Re: All motor h22a map
Posted: Tue Jul 21, 2015 12:15 pm
by h22aeghatchback
Bump.. My car won't stay on need this to get to my tuner
Posted: Tue Jul 21, 2015 1:36 pm
by hpmx18
post the file that you hava now so we can edit can help
Posted: Tue Jul 21, 2015 3:53 pm
by h22aeghatchback
stock h22 map I just changed injector size to 650cc
Posted: Thu Jul 23, 2015 9:22 pm
by h22aeghatchback
Bump
Posted: Sat Jul 25, 2015 10:48 am
by hpmx18
do you have a wideband on the car to see the afr
Posted: Sat Jul 25, 2015 12:28 pm
by h22aeghatchback
Yes I have a wideband I just need to install it lol
Posted: Mon Jul 27, 2015 1:03 pm
by hpmx18
install it and wire it to ecu to sho afr readings and post log of regular drive and a few 3rd gears wot runs if you can
Posted: Mon Jul 27, 2015 1:04 pm
by h22aeghatchback
The car won't stay on it has no throttle response either it will wet the sparkplugs the car was drivable until I upgraded to 70mm throttle body
Posted: Fri Jul 31, 2015 8:29 pm
by h22aeghatchback
So I got it to turn on for a bit but it is still too rich it wets the spark plugs and shuts off will lowering fuel pressure help?
Posted: Fri Jul 31, 2015 8:52 pm
by hpmx18
remove 15% from the fuel map or - 15 from overall fuel trim
Posted: Mon Aug 03, 2015 9:17 pm
by h22aeghatchback
So I couldn't get it to run so I now have this new map that turned it on afr was at about 10.4 at idle it stayed on until warm up and then shut off (wet spark plugs) thing is I have 650 cc rc injectors and the map is stock injectors so when I change injector size would I increase injector dead time to lean it out a bit?
