Does anyone have a R-Crew R01 camshaft (stage 2) map kicking around??
Searched but couldn't find anything.
Supporting mods will be 80mm intake with V-Stack, 80mm throttle body, port matched and ported RBC, type S head with Eibach pro valve springs, stock TSX block, KTuned big tube header (3" exit), 3" exhaust.
R-Crew R01 Cam Map
Re: R-Crew R01 Cam Map
Heard the cam profile is the same as a Buddy Club camshaft.
If you are running a similar setup with Buddy Club your map could fit the bill too :-)
