Onboard datalog crashing K Manager
Bath Tussue
- what vehicle you have: 2004 RSX
- serial number of your K-Pro: Will update in the morning.
- version of software being used (from Help, About): 4.0.8
- ECU part number (starts with 37820) and serial number (the number under the part number): Will update in the morning.
- KManager version (not 'the latest'): 4.0.8
- the calibration (as an attachment): attached.
- a datalog of a problem (as an attachment): Attached. Please rename as a zip file to unzip.
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc).: Hondata Intake manifold gasket. Replaced factory battery grounds with 4GA wire. Turbo.
- when and where you got the K-Pro: K series Parts. ECU was purchased from them new, sent by them directly to Hondata, and then sent to me.
- a specific description of the problem: When loading a datalog made with onboard datalogging, it crashes K Manager. To rule out computer problem, I load the same file on my friend's laptop. It also crashed on his laptop. My friend's onboard datalog file from his k-pro loads fine on my computer.
I can connect my laptop to the ECU with a USB cable and it will log just fine. Only onboard datalog causes the problem.
Bath Tussue
Re: Onboard datalog crashing K Manager
4.0.8 is listed as the latest production version software.
Do I update to the beta version?
Bath Tussue
The newest version of the software has the same problem.
Do the two datalogs supplied (track3.kdl & test v413 - 1.kdl) cause the problem?
Bath Tussue
Yes. They were both done with onboard datalogging.
Bath Tussue
This error is from my computer.
This computer does not connect to my car because it is a desktop computer.
The file loaded is track3.kdl
The log will load, the graph will show the whole duration of the log, but when I select any section of the graph, it crashes with this error.
Problem signature:
Problem Event Name: APPCRASH
Application Name: KManager.exe
Application Version: 4.1.3.0
Application Timestamp: 00000000
Fault Module Name: StackHash_e98d
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c0000096
Exception Offset: 05b83fd0
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 4105
Additional Information 1: e98d
Additional Information 2: e98dfca8bcf81bc1740adb135579ad53
Additional Information 3: 6eab
Additional Information 4: 6eabdd9e0dc94904be3b39a1c0583635
From the same computer, if I load the test v413 - 1.kdl, the graph of the whole log will show, but when I select anywhere on the graph, I get an error pop up box saying "Abnormal program termination"
Problem signature:
Locale ID: 4105
Bath Tussue
From the same computer above, I opened the program as Admin.
At the same point in time, this error popped up:
Invalid floating point operation
Problem detail
<?xml version="1.0"?>
<data>
<date>Jul 14, 2015</date>
<time>10:25:54 PM</time>
<os>Windows 7 Professional Service Pack 1 (build 7601), 64-bit</os>
<language>en</language>
<country>Canada</country>
<application>
<name>KManager</name>
<version>4.1.3.0</version>
<compiledate>Thursday, July 2, 2015 9:50 AM</compiledate>
<caption>Hondata KManager 4.1.3</caption>
</application>
<additional>
<SerialNo>0</SerialNo>
<HardwareVersion>0</HardwareVersion>
<FlashMemory>0</FlashMemory>
<FirmwareVersion>0</FirmwareVersion>
<MemoryLoad>35</MemoryLoad>
<RecordingMemory>16491860</RecordingMemory>
</additional>
<exception>
<address>0x00526642</address>
<exception>EInvalidOp</exception>
<message>Invalid floating point operation</message>
<class>TSensorGrid</class>
<form>GraphForm</form>
<control>cboTemplate</control>
</exception>
<stacktrace>
<trace>0x00526642</trace>
<trace>0x0042F2AC</trace>
<trace>0x0074B1F6</trace>
<trace>0x0074BB8F</trace>
<trace>0x007C21CD</trace>
<trace>0x007BC577</trace>
<trace>0x007C083C</trace>
<trace>0x007B7914</trace>
<trace>0x007BC3AA</trace>
<trace>0x007B754F</trace>
<trace>0x007BCDEC</trace>
</stacktrace>
<actionlist>
<action>Datalog actDatalogLoad</action>
</actionlist>
<undolist/>
</data>
Problem detail
<data>
<application>
</application>
<additional>
</additional>
<exception>
</exception>
<stacktrace>
</stacktrace>
<actionlist>
</actionlist>
<undolist/>
</data>
Bath Tussue
Something interesting: If I close the sensor window, it will work fine.
This is for onboard datalog only.
Any logs that I made realtime with the laptop with the USB cable works perfectly fine regardless of anything.
Ok, thanks for all the information. We've found the problem and fixed it for the next release. Unfortunately there is no workaround for the moment.
