Intake temperature measurement with the MAP-Sensor?
Posted: Fri Jul 10, 2015 9:41 am
Hi,
is it possible to measure the intake temperature with the Honda OEM (stock) (1,7 bar (10 psi)) MAP sensor or other like rdx (2,8 bar (26 psi)) or the hondata (4,0 bar (40 psi)) MAP sensor?
I would need this to measure the charge air temperature after supercharger and intercooler!
If so, how it is possible to display the values in the Hondata FlashPro Manager?
If it is not possible, what should I do / install that it works?
Thanks!
Thanks!
