Time frame on V.4 turn around
Posted: Sun Jul 05, 2015 11:32 am
by klone
trying to fix my ignition problem and hoping V.4 will do that
curious how long it takes to get the updated ecu back
thanks alot
Re: Time frame on V.4 turn around
Posted: Mon Jul 06, 2015 7:23 am
For an upgrade? Turn around time is 1 day (we ship the day after we receive it).
However I don't think upgrading to the KPro4 will change anything, unless the process of upgrading software and re-uploading updates the calibration, which you could do on your current system first.
Posted: Sat Jul 11, 2015 6:43 am
by klone
Hondata wrote:For an upgrade? Turn around time is 1 day (we ship the day after we receive it).
so have you guys ever seen this problem before? i have tried changing almost everything besides the ecu
Posted: Sat Jul 11, 2015 4:19 pm
Post your calibration. The MAP sensor looks bad from the datalog.
Posted: Sun Jul 12, 2015 7:16 pm
by klone
Thanks a lot.
B series MAP sensor and TPS
downloaded after tune.kal
Posted: Mon Jul 13, 2015 8:33 am
The manifold pressure is very high (70 kPa). It could be the MAP sensor - you can check by switching the ignition on but not starting the engine and see if you get close to 100 kPa reading.
Otherwise it is either the engine compression is low, cams are out, or the fuel tuning is way out. I noticed that the MAP is so high it won't run closed loop at idle.
The ignition is all over the place because the ECU is trying to control the idle (1000 rpm) but there are air leaks and the rpm is over 1200 rpm.
