S300 Not picking up AEM Wideband (SOLVED)
Posted: Mon Jun 29, 2015 7:41 pm
Hi everyone,
So Have the S300 V3
B16 JRSC EM1
Currently running the JRSC B16 map in the vault.
AEM UEGO (ordered the 30-4100 and got the 30-4110, Don't know if that makes a difference.
Serial # 33508.
So the car runs great a little tuning at idle was all it needed. The wide gauge works. I have the wires that go to the o2 sensor and the 4 wires on the other harness Red (power) Black (Grounded to the thermostat) White (Analog, that is going to the ECU) and the Blue that is not used.
Like I mentioned before the gauge works great but Hondata isn't picking up the signal from the white wire. I tested the voltage at the Analog port on the ECU and used the conversion chart supplied with the kit and it matches up correctly with what the gauge is getting. I currently have it hooked up to Analog 0. So I know the ECU is getting the correct voltage. Please note that I also tried to hook the white wire up to the D12 Pin and got no results either. I set up the analog parameters like in Hondata short cuts. I have read everything I would and had a veteran Hondata user try to help me set it up at well. With no luck! Thank you in advance!
So Have the S300 V3
B16 JRSC EM1
Serial # 33508.
