So as far as i can tell right now, my fuel pump isn't priming or running. the car is not wired with a main relay but like the attached. I don't hear it prime or run when i flip on the accessory and main switch. Does it need a sensor power input to keep it running once the engine starts along with the A7 pin from the ECU? Or does and will the A7 pin prime and keep running?
Engine is a B16A2.
S300 pump wiring with no main relay
Re: S300 pump wiring with no main relay
Solved ignore. above wiring is fine.
