Resistance based Temperature Sensor > 0-5v input
Posted: Tue Jun 23, 2015 7:20 pm
by Lyle_57IAL
Hey Guys,
Currently looking at logging oil temperatures to my S300 0-5v inputs. Seems quite hard to find a actual 0-5v oil(fluid) temperature sensor - If anyone knows of one please let me know !
However I have herd that it is possible to convert a resistance based temperature sensor in conjunction with a extra resistor and some supplied voltage to convert the signal to a 0-5v value.
Does anyone have a bit more information or a wiring diagram on how this would be done? and if it would also be possible to add to a sensor that was being used by a aftermarket gauge already?
Cheers guys:)
Re: Resistance based Temperature Sensor > 0-5v input
Posted: Tue Jun 23, 2015 8:52 pm
by mtber
Google MCP6SX2
It may be what your looking for.
Posted: Tue Jun 23, 2015 10:51 pm
This will be available for the S300 very shortly (I've added it in the last week).
The supported sensors are the Bosch 0280130026 (ECT) & 0280130039 (IAT) and the Delphi TS10075 (ECT) and Delphi 25036751 (IAT). All sensors are really common and cheap ($15-$20), and there are many sensors in each family with the same resistances. There are variants with straight threads + crush washers and also NPT sensors. You'll need a 1.5k 1% ohm pull resistor.
Details, including wiring, will be available when the software is released, which should be in the next week.
Posted: Wed Jun 24, 2015 2:48 pm
by Lyle_57IAL
Yes I am chasing a sensor for oil temperature though. And would this just simply be using one of the six analogue inputs ?
Posted: Wed Jun 24, 2015 4:27 pm
Use an ECT sensor for oil temperature. Do you mean one of the 8 analog inputs on the s300? (6?)
Posted: Thu Jun 25, 2015 12:37 pm
by jdelcorte
Hondata wrote:Use an ECT sensor for oil temperature. Do you mean one of the 8 analog inputs on the s300? (6?)
Very interested in this
Posted: Fri Jun 26, 2015 8:22 pm
by Lyle_57IAL
Yes thats correct. Apologies one of the 8 analogue inputs. But could you post a wiring diagram on how to wire the resistance based fluid temperature sensor with the pull-up resistor etc
Posted: Sat Jun 27, 2015 6:31 am
Posted: Sun Jun 28, 2015 1:42 am
by Lyle_57IAL
Hi Hondata
is a oem D16 ECT sensor scaled the same as the following. Would the ECT sensor or any of the below be suitable for oil temperature? If i used the OEM honda D16 ECT sensor what pull-up resistor would i need?
• Delphi 25036751 (air temperature)
• Delphi TS10075 (coolant temperature)
• Bosch 0280130039 (air temperature)
• Bosch 0280130026 (coolant temperature)
Posted: Sun Jun 28, 2015 3:25 pm
I did not calibrate the D16 ECT.
Either the Delphi TS10075 or Bosch 0280130026 will work for oil temperature.
Posted: Wed Jul 01, 2015 10:48 am
by Sir[Kneighf]
We are using a AEM Pull Up Temp sensor for oil temp has an almost linear output that can easily be corrected if using the 2 extra inputs on the ecu itself that can be calibrated with multiple point. The shortcoming is the slow response time.
