SManager 2.4.4
SManager 2.4.4
V2.4.0 (16 June 2015)
  • USB drivers updated to v1.0.3 (Microsoft Hardware Certified)
  • [S300 V3] Firmware version 5
  • [S300 V3] Added digital input ethanol content and fuel temperature to datalogging.
  • [S300 V3] Increased number of advanced protection inputs from 2 to 4
  • Added minimum speed to full throttle shift.
  • Fixed digital input unit changing when datalogging.
  • Added injector voltage compensation (dead time) quick select.
V2.4.1 (16 June 2015)
V2.4.2 (25 June 2015)
  • [s300 V2/s300 V3] Added analog input temperature sensor conversion.
V2.4.3 (15 July 2015)
  • Changed protection limit minimum rpm from 2000 to 2500 rpm.
  • Changed ECT compensation datalogging to read warm up compensation when cold
V2.4.4 (20 July 2015)
  • Added closed loop minimum coolant temperature tables.
  • Fixed ECT open loop fuel compensation under certain conditions
The USB driver has been certified by Microsoft so will install on Windows 7 and above without needing confirmation. It also is available in Windows Update.
Download here
jdelcorte
Re: SManager 2.4.0
Post by jdelcorte »
hello, how do you set up the flex fuel to datalog the percentage and fuel temp? do you use Analog Zero still on the V3?
Re: SManager 2.4.0
Oops, I didn't enable the sensor for ethanol content & fuel temp. I'll make another release shortly.
