b18 boosted
dc2danny
b18 boosted
Post by dc2danny »
just recently installed the hondata 4 port boost solenoid turned down to 32hz and ran duty cycle at 35% have a turbonetics turbo setup with external waste gate not running the rc 440s as I could not afford a set only have 270 I know its not enough but the car runs ok doing about 6.5 psi on the setup can I still run up the boost and up the duty cycle im at 35% stock map sensor and internals and I set solenoid at 4 psi activation any info would be greatly appreciated
Re: b18 boosted
There is no way you are only at 35% duty cycle at 6 psi on stock injectors. You need to get larger injectors to run and tune this safely.
dc2danny
Re: b18 boosted
Post by dc2danny »
I kind of figured that I apologize in advance if I give the wrong info im very new to all this hondata stuff and my mechanical expertise is a little average when I ran the car it read 6.5 psi on the s manager im going to check my parameters and relay better information thank you
dc2danny
Re: b18 boosted
Post by dc2danny »
the solenoid is at max boost at 100% normally closed at a fixed duty cycle of 35% variable frequency is set at 32hz cold and hot boost cut off is at 9.9
