Closed loop becomes crazy
Posted: Mon Jun 08, 2015 2:48 pm
by olivenoire
Hi there
I figure an important problem,
Sometimes my cars becomes totally lean at idle or something 10-12% TPS
The problem disappeared totally at wot but at partial throttle it is not good at all
I can see o2 sensor voltage cycling from 0 to 1 volt.
I can see my large band AFR alterning from 14 to 17...
TPS and INJ are near constant
CMD.CAM is constant too
And AFR is random
Sometimes edu stays in open loop instead of closed loop. In open loop, AFR are not bad
SO I wonder what can
And other problem : I try to fix it with deadtime, but in deceleration, sometimes (often) there is a little surge (injectors goes 1.4ms during a fraction a time) with 0% TPS...
Any advise welcome!
slow stable strim-variation o2.kdl
slow monté strim-variation o2.kdl
slow monté strim-low o2.kdl
slow intéressant 2.kdl
map_immo_final drive_deadtime.kal
Re: Closed loop becomes crazy
Posted: Mon Jun 08, 2015 3:04 pm
by olivenoire
With pictures, maybe it is easier to understand...
english is not my mother tongue...
clip_6 by
olivier gx, sur Flickr
clip_5 by
Posted: Mon Jun 08, 2015 10:19 pm
by olivenoire
Nobody here?
I will try to put some better log
Posted: Tue Jun 09, 2015 1:03 pm
by olivenoire
Nobody to helpme?
here the full log...
I really wish someone could help me
Re: Closed loop becomes too lean
Posted: Wed Jun 10, 2015 7:13 am
by olivenoire
Nobody wants or understand my problem
Discussing with some mate, I^m beginning to understand my deadtime are probably totally wrong.
I've send my kprov3 to CPl to upgrade to a v4
After while I will try to tune DT carefully at idle etc
Obviously latencies are the key...
Posted: Sun Jun 14, 2015 3:58 pm
Your deadtimes are far too low, even for stock injectors, let alone 850cc injectors. What injectors are they?
Posted: Sun Jun 14, 2015 9:39 pm
by olivenoire
Hi thank you for your reply
I'm actually quite sure my problem comes from injectors too
These are my strange and very noisy injectors
http://www.siemensdeka.com/product/80lb ... -fi114992/
About dead time, I've put what I've found here
Posted: Mon Jun 15, 2015 2:34 pm
I do not believe the values are measured in the same way. You'll need to find your dead time values by trial and error. For a starting point they should be around 1.2ms @ 14V and 1.5ms @ 12V.
Posted: Mon Jun 15, 2015 9:40 pm
by olivenoire
Hi
Thanks again
Ok I understand.
I will give a try as far and will give you a feed back
Kinds regards
Posted: Wed Jun 17, 2015 11:58 pm
by olivenoire
Hi
just received my brand new kprov4 yesterday!
Sound great stuff. Need to find how to plug ae30-4100 in digital....
But I've tried tuning DT.
Actually 1.2ms @ 14V and 1.5ms @ 12V is a bit too much. AFR stays at 10,5 at idle. Maybe I have to try longer?
IAT are too much too because it is 30°C outside actually so it is not easy to tune, probably because of compensation. As a result fan turns on and BAT is changing, because of piping and intercooler become hot
At first step I discovered these values are not bad at idle (furthermore with these values, surge at deceleration desepeared, and that's a great thing ):
13.00 13.96 15.02
1.00 0.88 0.83
As soo I add only 1% more Strim goes -5 or 7% without been able to stay at 0
But sometimes once again when cruising at 9-10% TPS, AFR goes lean. So I will try again increasing velues
I will try again and share log etc
Obvisouly it will be a total empiric and long way to sort this. But I'm pretty confident.
regards
Posted: Thu Jun 18, 2015 3:40 pm
by olivenoire
Today was a new day to test my AFR gauge
It is actually impossible to tune injectors DT better that I did.
I really wonder if the problem do not comes from injectors themselves.
Will try again tomorrow, but this problem is the most difficult to resorb I ever had with this car!
But today I clearly confirm the problems occurs when injection time is near 1,5ms. I wonder why it opens so little.
Will try to reduce the injector size kmanager
Probably it will increase inject time??
I put some maps and logs if someone wants to have a check
