S300v2 ECU Resetting Itself
Posted: Fri Jun 05, 2015 2:37 am
I was data-logging on-board (USB not connected) for 20+ minutes with P72 S300 V2.
The internal memory was 50% used
After downloading the data log, the data log, though viewable had lots of jagged lines on any sensor trace.
Also the ECU would not accept an calibration upload.
When I downloaded the calibration in the ECU, it was the stock P72 calibration (instead of my duno tuned calibration)!
What are the potential causes for this that should be looked into?
I have done shorter on-board data logs with no issue
I have installed the Analog wiring connector (on top of the heat sink) as per the help file picture
