Throttle dampening!
Posted: Fri May 29, 2015 12:41 am
by R-12914
In Flashpro Manager we have the option under "Throttle" -> "Throttle Parameters" = "1st gear throttle dampening enabled".
If we activate this option, the thottle opening speed is lower in first gear when the vehicle is moving.
My question:
Is it possible to allow/activate this option also in all gears (1-6, reverse) to dampening the jerky throttle response.
Could Hondata make this possibility?
I would like to test this.
In principle it should be possible for all gears, because there is also possible for the 1st gear!
Here is that what i mean:
Re: Throttle dampening!
Posted: Fri May 29, 2015 5:07 am
by typer86
Try this option. This will smooth the shifting and eliminate the jerks in higher gears if you press the clutch.
Posted: Fri May 29, 2015 5:55 am
by pepperdanky
The throttle dampening does apply to all gears. It is just most noticeable in 1st.
