lamba fuel table not displaying values
dimilo
Post by dimilo »
Hey guys,
I was doing some datalogging and I notice when I click on the "display lamba values" (shift+f4) that I'm getting a blank table. Was wondering whats up?
I'm using a plx wideband wired into the eld and kpro4, all other O2's are disabled.
any help on figuring out how to correct this?
here is a link to the image incase the embed breaks again
https://drive.google.com/file/d/0B3-K5b ... sp=sharing
Honda
Re: lamba fuel table not displaying values
Post by Honda »
In Kmanager go to:
Options
Settings
In Wideband input tap chose
2nd option - Use an external wideband input from ELD pin
Note this is for datalogging only and you have to disable temporary the ELD option in the calibration in misc tab. You have disconnected the ELD sensor, right?
ronac
Post by ronac »
I'm having the same issue. dimilo, did you resolve this problem?
My O2 sensor reads into the Kpro via the ELD but the lambda overlay doesn't work.
Spoonavant_89
Post by Spoonavant_89 »
Hey guys,
I'm in the process of learning "how to tune with Kpro" and I was wondering which are the fuel value units displayed on the tables.
The tables do not display any units. They are just numbers relative to each other.
