Possible Rolling Anti lag/launch control Setup?
Posted: Tue May 12, 2015 11:08 pm
So I saw this video earlier where this guy was using the launch control feature while he was driving at speed by pulling the washer stalk.
Said video : https://www.youtube.com/watch?v=OzqHX8vu2U0
I also found a thread on another forum where he explains how he got it to work, although he was using Kpro.
He basically said he's using the 12v signal from the "wash" function on the wiper stalk to an input on the ecu (e22 in his case).
Well my question is how can I go about doing this same setup with the "wash" function acting as the switch for the s300?
I see in the "Launch Control" section under parameters it has several options for which switch input to use. If I wanted to use the D4 (Service Connector Switch) am I correct in thinking that I just run the 12v power from the "wash" function in the stalk to the wire that goes into the D4 pinon the ecu? Or is that not how this works and is there more to it than that? I don't wanna do this wrong and send power into the ecu and fry it.
I know i'll have to set the launch control up for the rpm I want and move the max speed limit up and all that. I just need to know if my thinking for the wiring portion is correct.
And the reason I'm choosing the scs over the brake or another switch is because it's not doing anything. All the other switches are still used for a separate purpose. Any info is greatly appreciated. Thanks
