B20 turbo need calibration help
KILLASIKONCEPTZ
Post by KILLASIKONCEPTZ »
I don't have a local tuner in my area and the closest tuner is booked out a month. Trying to get a calibration that will help me put a few miles on car so I can make sure everything is working properly before I can get a tune on the setup. I have a b20 stock internals with head studs. Running RC 550 injectors walbro 255 pump. Ram horn manifold and a .57 trim t3/t4 turbo. Turbonetics wastegate 9psi spring in wastegate. I have stock b20 n/a tune to start it up it idles great and all just looking to see if anyone has a tune they are willing to share that might help me out. Thanks.
ericbalanzar
Re: B20 turbo need calibration help
Post by ericbalanzar »
try this
Zperformance
Post by Zperformance »
you might want to smooth the graph out a bit, the car should run better.
ronald1241
Post by ronald1241 »
this help me a lot thanks for that before my car cannot past 4000 RPM now is good but the only think i do change the low rpm my car do is up and down 1000 rpm to 600 rpm i put some gas to the map in that setcion now run good
