Gear compensation
Posted: Thu May 07, 2015 2:00 am
by sass
This table allows the ignition timing to be altered by gear. Positive values will advance, negative values will retard. Note that the ignition timing is change for all load and rpm values in each gear.
We have an issue: ignition timing not working for all gears and does not matter which racing maps we use.
Calibration
FG2/FA5, MAP based, Deatschwerks 1000 injector starting calibration
Re: Gear compensation
Posted: Thu May 07, 2015 6:54 am
Please post your calibration and a datalog of the problem.
Posted: Sat May 09, 2015 1:02 am
by sass
ok
Posted: Sat May 09, 2015 8:35 am
It is because the knock ignition limit is 60. Setting it to 0 will allow the gear ignition compensation to work.
Posted: Sun May 10, 2015 8:19 am
by sass
What's next?
Posted: Mon May 11, 2015 7:46 am
Check
Ignition -> Air Temperature Compensation -> Ignition IAT Applied to Ignition Advance
Posted: Tue May 12, 2015 4:19 am
by sass
bingo
Posted: Tue May 12, 2015 7:38 am
Good. I've updated the help file.
Posted: Tue May 12, 2015 11:22 am
by sass
thanks
