Tuning problem! datalogs don't show lambda values
Posted: Thu Apr 23, 2015 1:18 pm
by m_kluch
Maybe someone can clarify the issue for me. When I do a datalog in kpro I don't get any recorded lambda values in the tables section. This makes it hard for me to tune as I cant use the lambda overlay to adjust fuel. I have to guess at the percentages just by looking at the graph's A/F ratio. If it worked correctly it would make tuning partial throttle a heck of a lot easier. Can someone please take a look at my files and see whats wrong? Also, what do you think of the overall tune?
Re: Tuning problem! datalogs don't show lambda values
Posted: Thu Apr 23, 2015 2:24 pm
The information is there in the datalogs.
You need to make sure you have the settings for Lambda overlay in ranges that it is actually in and make sure that you have the check for tables follow cam angles check under options.
Posted: Thu Apr 23, 2015 2:34 pm
by m_kluch
I have low load set at 14.7 below 75kpa medium load 13.7 high load 13.2 above 87 kpa
Should "calculate for each cam angle" in the lambda overlay tab be checked? right now its unchecked
Posted: Thu Apr 23, 2015 2:47 pm
check it
Posted: Thu Apr 23, 2015 2:48 pm
by m_kluch
i checked tat box and now it works!!! problem solved. now my life is much easier!!!!
Posted: Thu Apr 23, 2015 2:49 pm
by m_kluch
thanks spunkster
