ECU does not support aftermarket wideband on B12, process for modification
Posted: Sat Apr 18, 2015 11:59 am
According to this page:
https://www.hondata.com/help/flashpro/i ... _input.htm
My ECU does not support using B12 for an aftermarket wideband. The above page states that you guys can modify the ECU to make it work. What is the process for doing this? How long is the turnaround time and what (if any) is the cost of this service?
Also, it shows that I can use E1 or E15 for this purpose. Is there any drawback of disabling & removing the factory pin from the ECU connector?
Thanks,
-Dave
Thanks,
-Dave
