d17 wideband pra prb calibration ?
MUGENVX9
Post by MUGENVX9 »
im running a kpro on my d17 and i want the wide=band to read i was told i need the pra calibration for the wideband to work im running the prb calibration right now can i copy the tune over to the pra and still have the same running car or do i have to do a retune on a pra calibration ...im also running the o2's from a k20a3
Re: d17 wideband pra prb calibration ?
A PRA based calibration cannot run a factory wideband, it is narrow band only.
What wideband are you using?
MUGENVX9
Post by MUGENVX9 »
Ive got the factory denso o2's from a rsx ...i was told to use these and it would give me a wideband reading
What ECU are you using?
Where are you located?
MUGENVX9
Post by MUGENVX9 »
I beleve it the ecu from a civic si ep3...im in cincinnati
You cannot just copy the PRB tables to a PRA calibration as the indexes and values may be different. Only the ignition will copy over as long as you have the same indexing.
MUGENVX9
Post by MUGENVX9 »
So theres no need for the pra if it dont support factory wideband im just trying to get the right anwsers to what i need for my kpro to show a/f from the wideband im running the 04-05 civic wide band witch are the same as the base rsx...i should be able to plug them into the factory harness and have a/f reading showing in the kpro...and i do not have a reading
A PRA calibration cannot run closed loop from a factory wideband.
MUGENVX9
Post by MUGENVX9 »
I dont understand how your even a admin and your not even reading the responce you already said pra dose not support a windband and i have also repeated this to you in comment...what do i have to do to get a wideband reading out of my kpro ... I have had nithing but problem from this kpro from day one and as the people of hondata are so arragant for any kind of input on there pos poduct ...what o2's did hondata use to produce the kpro if they where factory o2's then what whete they from? If its my kpro its self then ok its a pos ...ive spent $1200 on the stupid thing and cant even get the anwsers i need to fix it what awesome customer support...
What year and trim level is your vehicle?
There are complete details of the differences between the models located at: http://www.hondata.com/kpro_d17.html
Perhaps this will shed some light on the situation for you.
