H22 on ITB's TPS Load Sites
Posted: Mon Mar 30, 2015 9:27 am
by DRich
Hi All
I'm currently mapping a Honda Prelude fitted with a very high spec H22 engine on ITB and hondata S300 v3 ecu.
My question is can you add more TPS load sites to the fuel and ignition tables or are you restricted to just the 10 that are shown? I know you can add and edit the tps load sites by right clicking and editing, but can you have more than 10?
It would be nice to have some extra ones at the bottom end to improve progression from idle.
Re: H22 on ITB's TPS Load Sites
Posted: Mon Mar 30, 2015 9:50 am
You can set it to show 4bar tables then edit the load points as you want.
Posted: Mon Mar 30, 2015 10:14 am
by DRich
Great thanks
I don't need that many tps load sites so can i do the same and use 3 bar tables?
By selecting these pressure tables does it change any other settings anywhere else that i need to check to continue running it as NA on ITB's ?
Thanks again
Posted: Mon Mar 30, 2015 12:02 pm
You can use either 3 or 4 bar, but 4bar will give more resolution in the lower throttle opening area.
