No crank no start after failing to upload map to ecu
Posted: Wed Mar 18, 2015 1:11 pm
I have an 07 civic si with a new kw sc. As I was uploading the map to the car, I realized I forgot to change some settings, so i cancelled the upload (yes I'm a dumbass) and then changed the settings, and then tried to upload again and up came a pop up saying "The last FlashPro upload failed. Failure information : Code 0x00 Step 10 Address 0x000000
Explaination: Check the WEN pin in OBDII Connector."
So after that, no crank, no start, failed uploads, and nothing more. I'm thinking I bricked my ecu? Can anyone chime in and help? I'm pretty frustrated.
