aem wideband
aem wideband
Hi. After updating my kpro3 to latest version 4.08 of kmanager my wideband won't read when dataloging or in the display template. It just reads 10.0 in red. It was working fine before I done the update. This is on a uk ep3. Any help would be appreciated.
Re: aem wideband
You have not posted your calibration or a datalog showing the problem.
Re: aem wideband
here are the files
Re: aem wideband
Is there any solutions to this yet?
Re: aem wideband
What wideband are you using and what input are you using for it?
vtecinside999
Re: aem wideband
Post your calibration and a datalog showing this.
vtecinside999
Re: aem wideband
heres my calibration. you need datalog? Do it another day. But it shows 10.0 all time ;(
vtecinside999
Re: aem wideband
means theres is an mistake in the kpro? Please do the write up. this will be great. My english is not the very best so i didnt understand what you mean.
vtecinside999
Re: aem wideband
but theres one thing.... i display every analog inputs to see which port i use. I see input 0: 10.00 and Input 1: there was something, too.
vtecinside999
Re: aem wideband
i check it today.
This time i use Analog 5. same Problem 10.0 all time. Only on Analog 5, no other signal.
heres my Datalog.
heres my Datalog.
vtecinside999
Re: aem wideband
Ok thank you. I didnt make the things in settigns "use analog x as wideband" maybe thats the mistake. Will the stock then also work?
vtecinside999
Re: aem wideband
Yes i live in Europe. Use the PRA ECU and want the AEM only for Datalog and use the gauge to check everything works fine. But i have to Adjust the A/F because my car runs to Rich. Thats why i want to use the Analog in for datalog. If i do this in settings then the Analog in works for Datalog, and nothing change on the stock Lambda?
vtecinside999
Re: aem wideband
Ok i should do the settings and do a closed Loop run?
After this go back to open loop and disable the Settings what i made?
Also this works only with closed Loop?
vtecinside999
Re: aem wideband
I find something on internet. Same problem like me...
He wrote: Harness was upside down.
I dont understand what he means....
Maybe the backside of the gauge the harness is upside down? This will be great if this is so simple...
