Multiple programs that are switch selectable
mjalaly
Post by mjalaly »
How is this done with the S300? I want to be able to run a race setting for track days that i can select with a switch.
Re: Multiple programs that are switch selectable
Details on secondary tables can be found in the help file: http://www.hondata.com/help/smanager/se ... =secondary
mjalaly
Post by mjalaly »
How many separate tables can be set up? I dont see where it clarifies that.
You can have Primary and Secondary tables.
mjalaly
Post by mjalaly »
Any chance this and/or launch control can be activated via bluetooth from a tablet? I plan to run the tablet on my center console for hondata so instead of hard wiring switches, maybe i could use that.
No, you will have to hardwire switches.
mjalaly
Post by mjalaly »
Darn, maybe that should be an option on future releases.
mjalaly
Post by mjalaly »
when i switch maps using a toggle switch, is there also a way to change the boost? Run 1 map @ say 5psi and a second amp @ 12psi??
Please see the Help file for high/low boost control: http://www.hondata.com/help/smanager/bo ... st+control
mjalaly
Post by mjalaly »
Yes but can you assign one switch to control 2 functions or do i need two separate switches?
as long as you set them to use the same input then yes
