Vtec killers
Posted: Fri Jan 23, 2015 10:06 am
I need some help in getting these vtec killers running. I've done everything from witching off the vtec oil switch. Re-scaling the RPM index on the "low cam" tables, and a few other associated things in order to in killer mode.
Now the problem is that I can get the car to run, wants to start but then it floods it and the plugs get soaken. All sensors are working fine. TPS, CPS, etc...
I've taken a lot of fuel out, and even decreased the cranking fuel by 95%. The INJ is showing close to 20ms pulse width which is crazy, in my experience 2ms should be enough to start. Also the cams are very aggressive and the MAP is showing 96-100kpa during cranking.
Does anyone have experience tuning Vtec killers that can share some tips? or post a snap shot of their fuel and ignition maps so that I can get an idea on what values to start with.
