id1000 dead times. and ? about using a aem wideband gauge
luismercado120
Post by luismercado120 »
hi i would like to know what injector deadtime i should use for id1000. ive heard the numbers from id's website are incorrect so what numbers do i go by.also do i set the injector size at 1000cc or change that aswell, and my last question is im not having any luck seeing the afr's on my laptop. i have the aem wideband wired into d14 with the voltage offset at 0. but when i datalog i cant see afr's on my graph.what am i doing wrong
my set up:
b18b block
manley rods
je pistons 9:1
gsr head
ferrea valvetrain
skunk 2 pro 3s
oem ignition
hondata s300
c16 fuel
Re: id1000 dead times. and ? about using a aem wideband gauge
10v=1.90ms
12v=1.49ms
14v=1.20ms
16v=0.91ms
You should use one of the other inputs other than D14. D10 would be the first choice.
luismercado120
thank you for the advice
B18CR-X
Post by B18CR-X »
Hi want to ask what fuel pressure do we use with these deadtimes?
The dead times were made with 60 psi fuel pressure.
