ignition timing issues ... Help required
Posted: Sun Dec 28, 2014 10:12 am
by trinisir
good day
Engine : JDM b16a stock head and block
ECU : hondata s300
With the stock cams I had no issues setting the ignition timing as per ( select set timing enter 16 degrees and adjust the dizzy to suite)
I have installed dual valve springs and replaced the cams the exhaust is +2 and -2 intake.
I am unable to set the timing to 16 now.
I found some info not sure if it was correct.
1 cam degree = 2 crank degrees.
Therefore I set ( the set timing in hondata to 20 degrees ) and in doing that the crank lines up with 16 degrees.
Is this correct . If not please advise.
thanks for the help
Re: ignition timing issues ... Help required
Posted: Mon Dec 29, 2014 2:12 pm
by AREA876
Are you using Smanager online > set timing to lock the ignition timing at 16 deg.?
Posted: Mon Dec 29, 2014 2:44 pm
by trinisir
Yes I was using it online
Problem resolved
the issue was the timing light
thanks
