s300 v 1 help please
richardmichalski19
Post by richardmichalski19 »
Hi you guys im new to this hondata and would like.to tell you that i bought it used dumb move on my part here is my issue ! When i.down load the software it down loads
on the computer fine and when i plug the ecu in and turn the ignition on it finds the drivers ok but when i click on
the s300 icon nothing happens and i get an error
it dosent open any home.page.or window can some one help me walk through this i hope.i.didnt get.ripped off :(
So at.this.point i cant change any perameters at all can some.one tell me why.thank.please help
richardmichalski19
Re: s300 v 1 help please
Bump please help me get started
When you get an error what is the error message?
If you get an error when trying to open SManager to usual cause is anti-virus software preventing SManager from running, or deleting SManager.
http://www.hondata.com/forum/viewtopic.php?f=1&t=8240
richardmichalski19
When i get home today ill jump on there but it says something along the lines of something has been terminated and dosent open the page
richardmichalski19
Here is the the problem im having maybe you can help me please or.tell me an alternative!
richardmichalski19
Here is another one im getting
richardmichalski19
Sorry its up side down
The screen shots show two different things - an application error from SManager and a script error from a website.
With SManager you need to break it down into steps and tell us which step is not working.
- When you installed SManager, did it install without any errors?
- With the s300 not plugged in, can you start SManager?
- With the s300 plugged in and the ignition on, but SManager not running, can you see the s300 in the Device Manager?
- Finally, if everything so far has worked, start SManager, close all the windows inside SManager, then plug in the s300 and switch on the ignition.
Let us know how it goes.
richardmichalski19
Yes it installs with out any error i cant start Smanager at all when i click on s300.icon i get the first error S manager dosent open at all i havent.hooked it.up.to.the.car.and checked my devices
But i did get it to upload drivers thank you
richardmichalski19
The problem is when u first try to open smanager
Uninstall SManager. Download the latest beta version from http://www.hondata.com/downloads.html. Install SManager and try running it.
richardmichalski19
ok i uninstalled all the s300 software on the computer i downloaded the beta version and and when i was finished the hondata ecu guide came up
and it get the same application error the instruction at 0x74f399e4 referenced memory at 0x01a00180 the memory could not be read man why is this happening
Have you tried this on a different computer? It sounds like there may be a hardware issue on the one you are using.
richardmichalski19
Thank you it was the computer that was junk and i have an old one now but trying to tune a stock p28 w bolt ons can some one help me through the setup
