Posts: 10615 Joined: Thu Aug 15, 2002 12:13 pm
Post
by Hondata » Mon Dec 08, 2014 1:07 pm
KManager V4 supports the new
KPro4 , which has significant improvements over previous generation KPros, and also adds some new features to the KPro1, KPro2 & KPro3.
Changes in 4.0.2:
Added KPro4 support
[KPro4] Bluetooth
[KPro4] Ethanol sensor input
[KPro4] Speed sensor input
[KPro4] Dash output (AiM , Racepak & CAN )
[KPro4] Advanced protection
[KPro4] Live tuning
[KPro4] Autotune
Added VTEC minimum coolant temperature
Added minimum number of samples for lambda overlay
Added WOT compensation fixed flag
Added closed loop max TPS tables
Added fuel table deviation display
Right align numbers in the table and parameter window where possible.
Added settings option to expand the table window grid to fit the window.
Added fuel pump prime delay and on setting
Added VTC angle lock
Added option to auto size the table grid.
Added ignition controlled idle tables.
Changed PRB calibration to activate reverse lock out via pin B22 (secondary intake runner). This allows PND ECUs to be used rather than the PRB ECU.
Changes in 4.0.3:
Fixed VTEC min ECT preventing VTEC from engaging
Changes in 4.0.4:
Added KPro4 USB driver
Added shift light control
Added boost compensation by ethanol content
Changes in 4.0.5:
Don't show driver warning if KPro4 drivers are installed correctly.
Changes in 4.0.6:
Added information for MoTeC dash output and Digital Input / Output Wiring.
Changes in 4.0.7:
Fixed screen scaling for DPI scaling over 150%
This software has been released from beta
VitViper
Posts: 273 Joined: Thu Aug 27, 2009 10:38 pm
Post
by VitViper » Mon Dec 08, 2014 2:10 pm
Target Lambda ECT High is unusable due to the panel it's in is too small. See
Post
by Hondata » Mon Dec 08, 2014 2:15 pm
Thanks for pointing this out.
The workaround is to click on the Advanced tab and then back to Closed Loop Advanced.
D-Rob
Posts: 70 Joined: Tue Apr 29, 2008 6:11 am
Post
by D-Rob » Mon Dec 08, 2014 5:22 pm
With the alternate VSS options, is there any way to use the OEM sensor as a logged value and an alternate (say, wheel speed sensor) at the rear on a FWD car as the primary reference?
Post
by Hondata » Tue Dec 09, 2014 8:09 am
The alternate speed sensor is used as the speed input, so you only would see the rear wheel speed. What are you trying to do?
contectr
Posts: 155 Joined: Mon Feb 13, 2006 4:03 am
Post
by contectr » Wed Dec 10, 2014 3:40 am
Hondata, i take a look at the new software because i'm a lot interested for the wideband closed loop with aftermarket controller for my customers.
I see that is possible to have the closed loop on part throttle condition but for the WOT like the S300??
Honda Ep3 stock k20a2 jrsc
Knox
Posts: 139 Joined: Mon Jun 06, 2011 6:01 pm
Post
by Knox » Wed Dec 10, 2014 5:36 am
Today I downloaded the k manager v4.0.2 and upload my calibration to my krpo. After that my car starts to don't activate vtec (vtc working). My car is jdm integra type r with jdm k20a, my kpro is v2 on prb ecu. I datalog the problem which I attached the datalog and calibration and after I uninstall the v4.0.2 and install v3.3.1, now everything is perfect just like before.
EGK2082
Posts: 59 Joined: Mon May 05, 2014 2:45 pm
Post
by EGK2082 » Thu Dec 11, 2014 6:17 pm
kManager v4 can be used with kproIII?
1320k24EK
Posts: 24 Joined: Tue Dec 17, 2013 5:59 pm
Post
by 1320k24EK » Thu Dec 11, 2014 6:20 pm
EGK2082 wrote: kManager v4 can be used with kproIII?
Yes
EGK2082
Post
by EGK2082 » Thu Dec 11, 2014 6:23 pm
Thanks, I thought it is only for kpro4
D-Rob
Post
by D-Rob » Fri Dec 12, 2014 3:54 pm
Hondata wrote: The alternate speed sensor is used as the speed input, so you only would see the rear wheel speed. What are you trying to do?
Interested in comparing front to rear wheel speeds, although, ponying up for the traction control would be able to show me that. :P
Honda
Posts: 30 Joined: Sat May 17, 2014 9:59 am
Post
by Honda » Sun Dec 14, 2014 10:00 am
Hello.
I have problem vieweing ALL the new features in 1024 x 600 and 1024 x 768 resolution.
Thanks!
Post
by Hondata » Sun Dec 14, 2014 10:10 pm
Can you post the calibration? Email to
support@hondata.com if you don't wish to post it here.
VitViper
Post
by VitViper » Wed Dec 17, 2014 5:17 pm
Hondata wrote:
[*]Added boost compensation by ethanol content[/list]
Download
here
Yay! Now can we get this in S300 as well? And possibly expand the table to be compensation by gear... I can't imagine you'd ever really want to double the boost in 1st gear if it's already traction limited.
