s manager quits working
Jwaggz21
Post by Jwaggz21 »
i have an issue with smanager, i have windows 8 (it is not the rt version) and have downloaded the newest smanager from the hondata website. it works fine then i plug it into my ecu to run some data logging it works fine, but the moment i save the datalog and try to run another one smanager quits working and when i try and reopen it i get an error message " 'nan' in not a valid floating point value" i have to unistall the software then when i reinstall it will work fine until i try to save another datalog then the same thing happens. any ideas?
Re: s manager quits working
You will need top open the smanager.ini file in notepad and edit it. Delete the NAN and replace it with 0.
Jwaggz21
Post by Jwaggz21 »
where do i fine the .ini file? im looking around in the smanager folder but dont see anything with a .ini
Just download the most recent beta version from the downloads section of the website and it should resolve the issue.
