cooling fan will not turn off
reneruvalcaba03
I had my flashpro tuned and car dynode at a shop, ever since then the cooling fan on the car felt a little different but now the fan got stuck in the on position wether the car is on or off the fan stays on, the only way it turns off is if I disconnect the battery from the car. What can be going on, ive had it installed along with skunk 2 intake manifold and a throttle body for about 4 months now but it just now did this out of nowhere.
Re: cooling fan will not turn off
did you use ECT2 ecu input to connect any other device there?
if you did you had to disable ECT2 cooling fan radiator control,it's an option on misc on the calibration file.
if you are not sure for anything stated above contact your tuner in order for him to check your calibration.
Did you ever find out what caused this or fix it?
