I was looking at purchasing a few extra sensors for a car I'm working on and was wondering the best way to go about setting them up to datalog in the S300.
-Fuel pressure and Oil pressure (both will use AEM 0-150 psi pressure sensors)
-Rear wheel speed (will use the xenocron rear wheel speed sensor kit) I want to leave the existing speed sensor in the trans to monitor front wheel speed at the same time.
-Individual Cylinder Exhaust temp (will use the AEM 4 EGT kit)
Datalogging extra sensors
Re: Datalogging extra sensors
If you have V2 or V3 I can tell you Fuel/Oil pressure and EGT are easy. Just use the 8 analog inputs. I can step you through how I did it if you want when I get a chance. Has been a while since I did it so I can't give steps from memory.
I have no experience with the wheel speed.
blacksir2000
im trying to do the same thing can you please help me step by step with turning them on throught hondata smanager
thanks
and also from the aem 4 egt probe kit am i only using the 4 0-5volt wires coming out of the aem box
thanks
