need a good basemap please help
Posted: Thu Nov 06, 2014 10:51 pm
by Boostedjr
lsv turbo 70 trim 63ar id 1000cc injectors 70mm s90 tb hondata s300 v2 ecu in a p28 hondata 4 bar map sensor 14lb spring in wastgate weisco 10.5;1 compression css sleeves manlet turbo tuff ibeam rods motor is fully built problem is it will not idle at all I hold the pedal to the floor car has no throttle response and falls on its face and dies after a couple seconds please help thanks in advance
Re: need a good basemap please help
Posted: Thu Dec 04, 2014 3:44 pm
by hpmx18
post the startup file that you are using
Posted: Wed Jan 14, 2015 6:49 pm
by Boostedjr
start up file? how do i go about doing that? sorry im new to this whole thing i would appreciate your help
