92 integra b18c type r code 17 problem
HondaTom87
Post by HondaTom87 »
Hey what's up?
So I am pretty new to using hondata and I have gotte my car to run pretty good so far but I keep getting a code 17.
Now the car is a 92 Integra LS with a 97 jdm type r hydro swap. The motor has a ctr intake cam, 270 cc rc injectors, blox 68 mm throttle body, port matched intake manifold, plm big tube header, n1 crank pulley, and 14lb flywheel.
I uploaded the 01 type r hondata base map and adjusted the idle and it runs ok. My problem is everytime I drive over 25 mph I get code 17 for vss and I can't figure out why. I do not however get any codes when I plug in my xenocron chipped pr4 ecu that has a gsr base map.
Any help on this would be great
AREA876
Re: 92 integra b18c type r code 17 problem
Post by AREA876 »
Use Smanager to see if the ECU is data logging the VSS
HondaTom87
Will do.
I will let you know what I find later today
