how to calibrate tps in kpro
viggen
Post by viggen »
hello.im very new to kpro.please help
i believe my tps sensor has died.im about to fit a new one in the next few days....what do i do to calibrate the tps?
do i need to fix tps using a volt meter to get .5v closed tb and 4.5 WOT.then move onto calibrating in kpro manager
is there anythink i need to do in kpro manager?if so what.and how do i do it?
step by step quide would be great
thanks.
Re: how to calibrate tps in kpro
You can calibrate it in KManager by rotating it until you get it as close to zero as possible when reading from it.
viggen
Post by viggen »
ok thanks.
at the moment
min is -0.1
max 101.9
is this the angle of the tps.or did the tuner put these numbers in to kpro ?
thanks
That was probably the read values when it was last calibrated.
viggen
Post by viggen »
hi
ive fitted my new tps.but kpro will not alow me to change the tps settings.
it will not even let me read the values...it wont let me click read min or max.please help
You must have your calibration loaded, datalog, read both value, then upload the calibration when done.
viggen
Post by viggen »
please can you explain.step by step...ive only had kpro a week.and still working out how to use it...
do you mean i have to do a datalog with new tps fitted.then bring up datalog and calibrations together?how do i do that?
then click read min,max.save and send back to the ecu?
thanks,im very greatfull for your help
Have you read the information in the help file: http://www.hondata.com/help/kmanager/kn ... =scale+tps
viggen
Post by viggen »
yes i have thanks..but the "read" buttons on the scale tps min,max ..dont work.they cant be clicked.
You must have your calibration loaded into the software and be datalogging to calibrate it. Once you have calibrated it you must upload the calibration with the new settings to the ECU.
viggen
Post by viggen »
thank you very much.i will try this when i get home on monday.
just to confirm can all this be done with the engine off?
thanks you very much again
viggen
Post by viggen »
thanks for your help you are a legend..
my tps min is now
min 4.5
max 96
is this ok?
4.5 was the lowest i could get it
You should adjust it at the throttle body to be as close to zero as possible.
viggen
Post by viggen »
i thought i had.when i fiited it.the sensor was full counter clock wise.and was reading 12.so i went full clock wise and got the 4.5 reading....
do you think i will get closer to 0 with the sensor in the middle?
read it while adjusting it at the throttle body.
