Problem with water temperature compensation table.
Starter
Post by Starter »
This is not for the first time I wrote here, this is my first topic
with strange problem viewtopic.php?f=19&t=17563 .
You know if I have some problem with Hondata S300, for the first of
all I read manual, try read many forums and topics to find the answer.
After cold start ECU using water temperature compensation tables(High engine load) for some
time and those tables didn't fit to my engine(I don't know why). Most
of the time I run in open loop operation, that's why I start changing
Open Loop High engine load - water temperature compensation table, but
nothing happens. I can place any values in those tables but the
picture remains the same:
ECT c. - from 30% at 40C(100F) to 20% at 75C(170F)
Why?
Re: Problem with water temperature compensation table.
It is very hard to glean anything from just a screenshot.
Starter
Post by Starter »
Spunkster wrote:It is very hard to glean anything from just a screenshot.
No problem.
Why do you have seconday tables set to always on? If you overlay the secondary tables trigger in the graph with the ect an iat corrections you will see a direct correlation.
