Honda S2000 AP1 - just installed KPro - got error DTC P0135
Posted: Sat Oct 25, 2014 5:33 am
Hi,
so I have just finished KPro install on my S2000 AP1. My car is pretty much stock (CAI + cat back). The car starts fine and idle. After few seconds after start I always get the code 41 (P0135 Primary HO2S heater circuit malfunction).
I have checked this error against Helms (for s2000). Wiring is ok, battery voltage is on the correct pin of the sensor terminal (but not between them). HO2S has 3.6 Ohms on heater pins (helms says around 3.3).
EDIT: I have wideband plugged after cat. During first seconds of idling shows around 16 to 17 AFR. It seems like that exhaust gases are extremely hot, because after few secs since start I can see hot air coming from the exhaust header.
I don't know what else to check and if I should consider my o2 sensor as bad one. Please help. I'm attaching calibration and datalog recording for few seconds from engine start.
UPDATE: I have took out my primary O2 and tried to heat it up using torch and measure output voltage. It works pretty good. Also impedance of heater pins is ok I guess (around 6 ohms when sensor is hot). I have checked service manual for RSX and there is 10 - 40 Ohms expected for secondary O2 sensor? So question came to my mind ... Do I have to change my original S2000 primary O2 for something else or it should really work???
I also have noticed that KPro is showing 4.08V for O2 sensor all the time.
Many thanks. George
Many thanks. George
