Boost Control was working, now isn't.
crxdonwon
Post by crxdonwon »
P06 ecu, S300 v2 with BBG, using the Hondata Boost Solenoid.
My car was tuned last year by Alex Pagan at Humble. Boost control was working great. Put in a Rywire tucked harness, which has nothing to do with my wiring to my solenoid. Now it will not build any more than the gate. Gate is 12. I have not changed anything in the tune. I have verified that the soleniod will click when given 12vdc. I have verified the 12vdc on with key to one side of the soleniod. I do not get 12vdc across the soleniod wires. A 11 is the other wire for my solenoid. I have tried switching the wires. Still only 12 psi on gate. Verified the hoses going to solenoid at least 32 times. Port 2 to wg top port.
Port 1 to tee, to wg bottom port, to manifold pressure. All of this was working until the new harness. Any ideas would be great.
Re: Boost Control was working, now isn't.
A PM6 ECU cannot be used with Hondata.
If you have proper ECU with s300 you can go to the online menu in SManager and use the test outputs function. If it still will not work then you have either a wiring fault, or the transistor in the ECU has been damaged.
crxdonwon
Post by crxdonwon »
Damn autocorrect. I edited the original post. P06.
My bad.
crxdonwon
Post by crxdonwon »
Thank you I will check that now.
crxdonwon
Post by crxdonwon »
Verified in test outputs. The solenoid sings. The only other thing I have done is updated SManager to 2.3.3.0 then uploaded my pump gas tune. But since then have also tried my race gas tune and same results. I know it's a setting in here somewhere. I'm just not sure what I can play with.
crxdonwon
Post by crxdonwon »
Man I just put the ecu back together and back into the car. The thing is.... I didn't have this problem until I updated to the newer SManager. Now I'm racking my brain. I know it's a setting that didn't carry over when I did the update.
crxdonwon
Post by crxdonwon »
Do you have teamviewer? Might be easier if you could look at it. I'm not trying to waste anyone's time. A quick look may be easier than waiting on replies.
AREA876
Post by AREA876 »
Post calibration
