Way to tell if calibration is MAP or MAF based?
Diversion
Post by Diversion »
How do we tell when loading them up in Flashpro?
Re: Way to tell if calibration is MAP or AFM based?
Look in the fuel section of the calibration window.
see fuel table type: http://www.hondata.com/help/flashpro/fu ... %2Bdensity
Diversion
Post by Diversion »
Spunkster wrote:Look in the fuel section of the calibration window.
Looked all over Flashpro and don't see where you can see "Fuel table type" check box as indicated in your link.
pepperdanky
Post by pepperdanky »
Then it is probably a MAP calibration. Under the "Fuel" parameters do you see "Fuel low" and "Fuel high" listed? If so, it is using MAP for fueling. The AFM calibrations do not use these tables.
Diversion
Post by Diversion »
Yes there's a fuel high and fuel low parameters on this tune.. It's a stock based tune and I flashed yet I still have rev hang.. And i'm hearing no matter the tune, if it's MAP based it automatically removes rev hang.
