Stock map and rev hang...
Posted: Thu Oct 02, 2014 6:44 am
by Diversion
Does the provided stock based map for the GD3 Fit already get rid of the rev hang? I am 100% stock at the moment and just interested in flashing something that will eliminate the rev hang for now..
Thanks,
-Div
Re: Stock map and rev hang...
Posted: Mon Oct 13, 2014 12:00 pm
by Diversion
It appears flashing the stock map via Flashpro does not remove rev hang in case anybody cares.
Posted: Mon Oct 13, 2014 1:30 pm
by pepperdanky
Set the overrun fuel cut delay to 10ms. There will be less hang but it will be a rough transition off-throttle when the injectors shut off, especially in the lower gears. You can test different values (20ms, 30ms, etc.) to see what delay will give the best compromise between rev hang and jerky off-throttle response. The stock value of 70ms seems a bit high.
