S300v3 rev limiter, cel shiftlight and 2 step not working???
Type_r_eg
Post by Type_r_eg »
Hi I've had my hondata for about a year now and when I first got it the rev limiter and two step worked(launch control) but I had to deleted map and redo it and ever since then they both don't work. I've already updated s300 from the latest update and also when I go into sensors it shows that it's turned off.
I've also set the rev limiter to 5k and nothing.
My launch control I've set to always on, 4500rpm and second box to 4400rpm and 10 on fuel and 15 on ignition.
And also my cel shift light does not come on when I set low like 7k.
Need help
Thanks in advance
Re: S300v3 rev limiter, cel shiftlight and 2 step not workin
What is the serial number on the s300 board inside the ECU?
From Help, About, what is the version of software that you are using?
Post your calibration as well as a datalog showing the problem.
Type_r_eg
Post by Type_r_eg »
Sorry for the late reply. I really appreciate the help.
The serial number for hondata is 30524.
And the version is 2.3.30
Type_r_eg
Post by Type_r_eg »
S300 ecu
Type_r_eg
Post by Type_r_eg »
Calibration is from the jdm b18c from hondata.
Type_r_eg
Post by Type_r_eg »
Anybody help?
You still have not posted the calibration or a datalog showing the problem.
