new to S300 and got problems!
touge tom
Post by touge tom »
hi all...
iv'e placed my S300 in the usdm p28 ecu(pre prepped for S300) and up loaded a 2001 type r calibration.
but the cel light stays on.
motor idles fine but @ a 11.1:-12.5:1 AFR.
is it necessary to have part no# GC98401158 connected to the S300 data log pins? and if so where does the wire go?
all help is appreciated in advance!
from Tom in sydney australia.
Lazysk8r2
Re: new to S300 and got problems!
Post by Lazysk8r2 »
use the s300 to read what code its throwing. Inside smanager there is a error code button that will tell you when your connected.
Street Tuner/Dyno Tuner
That harness does not have to be connected. YOu need to read the error code and that will help you determine what to do next.
touge tom
Post by touge tom »
all sorted guys. i had to turn off the ELD,knock and alternator control for the p28.
